Evinrude age and specs
radsrh
I need the age of a 20Hp rude, Model number E20CRC0S Ser number E0507773. I need to replace the water imp and we are running short on summer so if someone could also tell me the lower unit torque and the location of the shift rod disconnect. Thank you I have a manual on order but by the time I get it, it will be time to put the boat up for the winter.
Joe Reeves
Re: Evinrude age and specs
The engine's a 1985 model. Torque... just tighten the lower unit bolts. Nobody torques those bolts that I know of. Shift connector is in back of the plate on the side of the exhaust housing half way between the powerhead and the lower unit.
radsrh
Thank you Joe for your Reply, I knew you would come through for me.
