Evinrude 95 oceanpro 1998 issue after replacing fuel senenoid switch
jasontd101
Fuel senenoid switch had a hairline Crack on red stem and was leaking fuel and engine would not start. I replaced the seal and switch with the kit and now it starts but runs very poorly and coughs and sputters. It ran fine before the switch went bad and now it will not stay running for more than 5 - 20 seconds. Any idea what could be the cause? Kindly note it ran fine then I turned off the engine and then went to start it again 3 hours later and would not start, I tried starting it for a good while before I took the air filter off and saw the fuel at the bottom of the engine and fuel coming out of the fuel solenoid switch. You think the actual fuel senenoid went bad as well or did I cause some other issue trying to turn the engine over multiple times while troubleshooting the issue? Any help would be greatly appreciated!
daselbee
You might have made a mistake when putting the red cap back on the solenoid....it is a little bit tricky, and there is a pin that can break off the red manual lever shaft....
If you did not assemble it right, then it could be leaking fuel around the valving mechanism, and flooding the engine...and therefore the crappy running and stalling.
First, make sure the red lever is positioned properly, in that the lever is aligned with the solenoid body.
If it is leaking around the valving mechanism, your primer bulb will not firm up when you pump it.
Also, you can pull one of the small fuel lines coming off the red cap and observe fuel coming out basically when it should not. Fuel should only come out those small lines when the key is depressed, or when the red lever is in the manual position.
Lastly, if it is leaking....you can take a small needle nose vice grip and pinch off the larger of the three fuel lines to the red cap. That is the incoming fuel supply.
If you pinch it off, and the engine now runs and idles properly, then you need to re-look at the red cap fuel valve for assembly errors.
