Evinrude 90 fitch dies at full revs
aclam
Can anyone help: our 1999 fitch runs perfectly throughout the rev range until it gets to max throttle (5500 REVS) it activates the S.L.O.W. safety function. When I turn off the engine and restart it, everything is fine again. The problem seems worse if the throttle is moved to wide open quickly.
Had the engine checked at local service center but they could not replicate the problem on the test bench and could not suggest anything else.
:confused:
seahorse5
Re: Evinrude 90 fitch dies at full revs
Were there any codes stored in the ECU when the dealer used the diagnostic software and laptop to check things out?
Did the dealer check the throttle position sensor adjustment and voltage output from idle to WOT to see if it was in spec?
Do any of the warning lights come on when the motor goes into SLOW?
aclam
I will check with the dealer for the code details and throttle sensor.
The check engine light comes on when in SLOW.
seahorse5
An overheated ECU also gives a CHECK ENGINE alarm and puts the motor into SLOW. Check the ECU, VST and their cooling hoses for restrictions if that is the case.
