Batchley13
Thread starter- Joined
- Nov 1, 2015
- 6
Ok guys I have read numerous posts on here about the problem I am experiencing and have troubleshot everything I read but still have the same issue.
The motor will not stay running at high rpm's. The motor is not getting enough fuel. When I am out on the water and take off, it runs great for a minute and then starts dying off. If I pump the primer bulb it recovers and runs great but I have to keep priming it. So I know what the problem is but I cant get it fixed.
Here's what I have already done. I replaced the fuel pump, I cleaned the carb twice, and I replaced the primer bulb. I disconnected the fuel line to the carb and pumped the bulb. Gas came out fine. So I figure the pump for whatever reason is not able to keep up. I pumped the pan full and with the fuel line disconnected started the motor. Gas was coming out but only dripping despite whether or not I revved the engine. Shouldn't it come pouring out at high rpm's? I hope that nothing is wrong with the compression. I took the pump off and put my finger over the hole and pulled the motor. It was sucking and blowing. The only other thing I can think of is maybe the float needs to be adjusted in the pan. Maybe it is not filling up all the way.
I need help on this. It has me stumped. If it gets enough fuel it runs great. Please advise. Thanks
