Evinrude 9.9 change to 15 hp carb
Kingkat33
I have a 1992 evinrude 9.9 and want to put a 15 hp carb on it. I have been told that the 1992 model you only have to change the carb to get more hp. Is this correct? How do I identify the correct carb to use if it will work?
boobie
Re: Evinrude 9.9 change to 15 hp carb
Go to shop.evinrude.com and look up your motor/s and check the part #'s.
SCduckhunter
If im not mistaken the intake manifold throat diameter is slightly larger on the 15 hp as well...they should all bolt the same, just a bigger diameter opening..i may be wrong others with more knowledge could clairify..
boobie
That is correct..............
tomhath
Master Chief Petty Officer
Most people who've done the conversion are disappointed. You might get a little more speed at WOT only, but starting and idle suffer. And there's no difference at lower RPMs because the bigger carb throat doesn't help when the throttle plate is closed.
