Thanks but iv'e tried a couple of times but no response.. back ground for request is i paid to have a 15hp carb installed on my 9.9...
suspect the original carb was jetted out instead ... engine symptoms similar to what leeroy's page states.But thanks for the reply.
my first forum EVER...
The side by side pics of the the 9.9 and 15 carb throats is in the '74 - '92 repair and maintenance section: http://www.leeroysramblings.com/Johnson 9.9_15.htm I don't know the specific specs for the throat sizes, but you should be able to look into yours and determine whether it's the smaller or larger throat, based on seeing the pics and making a comparison.
Not sure whether you are having difficulty locating the relevant section or getting to the site. I don't think there are specs shown, although probably part numbers.
Post a picture here and someone can likely tell you based off of that. If indeed it was just re-jetted, I hope he didn't swindle you into paying $200+ for the "swap".
