Re: evinrude 9.5hp model - 9122R
thank you - great information, especially since I have already bought automotive 90 wt. oil - will take back and exchange for marine 90 wt.
clete
a pasture down the road was going to be developed for subdiivison as progress makes it this way. live in rural jackson county ga. there was an old sea king 13-6" v-hull jon boat in pasture that had been used for water trough for cattle. boat was full of water so know dosent link. the knew developer (development since stopped from recession) planned on bulldozering down fencing, boat, prep for develpment. I asked for the boat and the new owner said take it. friend gave me 9.5 evinrude cause too big for his duck boat. the 1971 motor been setting-up for many years under house, this has been quite a project - learning as i go. basically loosing, regreased, added plugs, wires, bought plastic walmart tank, lines, pumps, connectors, etc. have gone thru the process of getting it registered thru ga. dnr, working on on old EE-ZZ Load trailer left in barn Dad' used with his original thomson bros. cypress strip boat. have taken trailer down to bare metal - going back with primer, new lights/wiring, wheel bearings, wheels/tires/ etc. so getting close.
main concern - get motor running. replaced points, wires, plugs (plugs set at .030). can get the motor running with help of starter fluid - but engine will not stay running, new points - .020 gap, getting fire to plugs and continous fuel flow to the carb, (rubber 5/16" tank line is 11 foot long cause wanted it in front of boat w/hand-pump 2' from engine - don't know if this is an issue?). took carb apart, cleaned, but feel problem is in carb. engine fires off especially first in morning - then have to wait to next day to get it fired off again. longest its' run so far is 5-6 seconds . am I right in assuming carb is flooding (then leaking back down overnight)? took carb off once & cleaned - but feel may still have gunk in carb jets/openings or assembled back incorrectly. it is old type - 1971. 9122R. with first new plugs - dealer sold be wrong plugs - were approx 1/8" too long and mashed in top-hook on plugs to where there was no gap - now have correct plug - Champion j4c. hope no serious damage done there. never ran with them but about 3-4 seconds.
thanks for yalls help - clete
