evinrude 9.5 fly wheel issue!
benvan77
K I redid the coils and points. When reassembling, fly wheel goes on over key, but will not rotate without reaching a blockage that keeps it from going a half revolution.
Help please.
hardwater fisherman
make sure your coils are not sticking out past the mounting bosses. and be sure all wires are tucked in and not catching the flywheel.
reiddo1
There is a small adjustment you can make via slotted holes in the coil screw mounting holes which should allow you to install them without rubbing on the flywheel magnets. Just loosen the screws and move the coils closer to the center line of the crank.
