Evinrude 9.5 drive shaft won't seat.
thatone123
Banned
I obtained a Evinrude 9.5. I am familiar with these motors and have replaced lower unit seals in the past, but this has me stumped. The top of the drive shaft was salted into the motor drive shaft socket. The driveshaft pulled out of the lower unit when I separated the upper and lower half's of the outboard. I hung the outboard upside down with an old rubber fuel hose wrapped around the shaft and after a few days of Aerocroil and pounding the driveshaft it parted ways and the motor dropped onto a cushioned cardboard box and I thought all was going to be fine. Now I cannot get the shaft to go back into the lower unit gear housing. Will it go in once it is out as I always made sure in the past not to take it out.? I've pushed and pulled and turned the prop and shaft at the same time and etc.
Honorary Supreme Mariner
It should just slide back in with no effort required.----Take the bottom end apart as something is wrong in there !!
