Evinrude 88spl
makjmf
I have a question - my uncle recently gave me his boat. It has an evinrude 88 spl on it. Ab :confused: out 2 years ago he had it completly serviced and then put it in a wharehouse. All fluids were drained out of it. Well, the starter turns, it smells like it is getting gas, the spark plugs look brand new and are wet. Fuel pump looks good. Before I take it into a boat repair shop - I was just wandering if there are any suggestions about what it may be? Is there a secret that you would only know with a manual. Thanks in advance.
angus63
Re: Evinrude 88spl
Try a couple of sprays of premixed fuel in the carbs after the plugs are cleaned.
makjmf
Re: Evinrude 88spl
Thanks - I will try that and see what happens
OBJ
Re: Evinrude 88spl
Hi makj,<br /><br />I'm going to assume that it won't start since you really didn't point out the problem in your post.<br /><br />First, are you using fresh gas with the proper 50:1 oil mix? Very important.<br /><br />When trying to start, are you pushing the key in to choke and is the cold start lever up?<br /><br />Does the battery spin the motor very quickly?<br /><br />Setting for two years could mean the carbs have gummed up. Running the motor dry dosen't really get all the fuel out of the bowls. I agree with angus, try some premix in a spay bottle and see if she fires.<br /><br />Not try to insult you with the questions. I just don't know if you are a first time boater that has gotten his first boat or not.
makjmf
Re: Evinrude 88spl
No (yes) it won't start. ANd yes this is the first boat. AND..... I am a girl!!!But, I have a boys help. Yes, we used the 50:1, the engine is fast(is that good) Manual is ordered. Not sure on the key thing - I am going to try that now. Also, tomorrow putting in the mixture to the carb. Thanks!!!!!
OBJ
Re: Evinrude 88spl
My most profound apologies mam'. The key thing, when you go to on or the first click over, push in on the key. This will energize a primer solenoid on the engine that will shoot raw gas into the throat of the carb for cold starts. On your control box, if it's an OMC control, their will be a second lever. Pull this lever up for cold starts. It will lay flat when not used. Or, some controls are "flush mount" controls. With these types, pull out on the handle and then forward. This lets you give the engine throttle with out putting it in gear for cold starts. Some controls will have a button located at the lower end of the handle. Push in and push the throttle forward for cold starts. Again, please keep us posted.....mam'.
makjmf
Re: Evinrude 88spl
That I will (keep you posted) Thank you very much kind sir!
fishbone88
Re: Evinrude 88spl
makjmf: if you are getting ignition from the battery and the starter is turning than you need to check for the three basics fuel, compression , and spark. 88spl are good motors and easy to fix on yourself. if the motor been sitting up for two years please don't use any of the old fuel in it. vanish made half build up in the gas tank as well if its a build in tank. see if you are getting gas to the carbs you didn't state what year your motor was you may have a red manual primer solenold switch if you do press the fuel pulp intil it get hard and turn the arrow outward if the motor start turn the arrow back in. get your compression check. to see if you got a good motor are not. check for spark<br />try to do this without shocking yourself to death.<br />get some rubber glove and some rubber handle grib <br />to hold the spark plug caps to the back of the block to see if you get spark.
makjmf
Re: Evinrude 88spl
Thanks for all the information - we are going to try this weekend and if none of this works - to the shop it goes!
