Evinrude-88HP SPI Power trim & tilt
LAMGURU
I just purchased this motor. the power trim & tilt relay/wire box was so badly corroded and several of the wires were broken off and i can't figure which connection goes where. The corrosion was so bad it ate some of the screws for the wires right down to knubs.
Does anyone have a good wiring diagram they could forward me for this application? It is a TWO way relay system, not the single relay. motor / relay box is from the 80's
thanks!
tashasdaddy
Re: Evinrude-88HP SPI Power trim & tilt
2 wire or 3 wires to the motor?
LAMGURU
It is a two wire. Blue, and a green
