James spl
Thread starter- Joined
- Jan 17, 2021
- 17
Just bought this motor. It was painted and I can't find model number plate so I don't know the year. Possibly 1986-1989. No compression on #4 bottom left piston. 70psi on #3. 110 on both 1&2. Motor still cranked and started with compression issu, not to mention the cracked bottom carb bowl leaking on both plugs. Had to pump primer bulb to keep it running. Water was coming out fine no problem. Only ran for 15 seconds on muffs. I was warned about the compression issues before purchase. Cost if brought to shop $2,500. Anyone could lend some knowledge on what I'm up against?
