After 1 days use this season, above motor refuses to start. Compression >100. Spark appears to be OK. Cleaned out carb, checked timing. Does not even fire. <br />--------------------------------------------------------------------------------<br /> <br />--------------------------------------------------------------------------------<br />Well here is some progress.<br /><br />I checked the timing again .... flywheel timing mark aligned to the mark on the engine case ... distributor wheel aligned to the button .... nothing.<br /><br />In desparation I tried moving the timing 90deg, then 180deg, then 270deg, at which point vrooooom ... off it went like the proverbial bat out of hell.<br /><br />Intrigued by this, I took it to the lake, and the boat worked the best is has ever done ... for about 15 mins then got all rough again. I moved the timing belt another few notches, and got it to run just as sweet ... for another 10 mins .... at which point it went out again !!<br /><br />So it appears that the timing is slipping out ... but I cannot understand why. Can the flywheel slip against the crankshaft ? Can the wheel on top of the distributor slip in relation to the rotor position ? It is not the belt slipping .... the relative position of the flywheel mark and the distributor wheel marks don't change ... but the setting of the distributor wheel that makes the engine run sweet does.<br /><br />Any suggestions ??
