Evinrude 70hp - Year/model # for rebiuld.
Just_starting_out
I'm trying to get the model # and year of my 70 hp Evinrude. As I'm getting ready to rebuild this engine for a winter project.<br />I want to purchase a OEM service and parts manual for this engine. <br /> <br />I only have the S/N :C7169366 that is on the frost plug.<br /><br />Checked everywhere on motor for the model # and year,still no luck. However from the head gasket p/n. I beleive that the year is between 1977 to 1985. The engine color is light blue almost grey. The engine cover is the same color with Evinrude written on the side in a dark Navy Blue Outline. It also has three (3) small stripes around the cover. Top - Red, middle - White , bottom - Blue. <br />I also included all the P/N that I could find on engine. Maybe this is going to help. Thanks for any help that you can give. Engine is apart & I'm attempting to do a rebuild. <br /><br />70 HP Evinrude <br />Model:__________ <br />Year: __________ (1977-1985??) <br />serial # C7169366 <br /><br />P/N Description <br />313839 Bracket <br />313840 Bracket <br />316664 Bracket <br />324316 Bracket-Throttle/Shifter cables <br />511938 rectifier <br />323669 Carb. - Manifold <br />313355 D2 Carb. # on bottom cover <br />393546 Carb. # Stamped on Carb. with <br /> marker (70) (X3) <br />386652-D2 Carb. Cam for Throttle <br />B1 328568 Carb. S/N <br />320953 Connecting Rod <br />323067 D1 Cover/Shield bottom of Motor <br />325044 D2 Cylinder Block - Bottom <br />389235 D1 Cylinder Block - Top <br />582138 OA 2S4 C.D. 3/6 Power pack <br />324833 Exhaust flange <br />322778 Exhaust -Mounting bracket <br />582641 Flywheel <br />385780 Fuel pump (vacuum style) <br />321796 Gasket - Exhaust <br />313413 Gasket - Head Cover <br />323681 Head Cover - Bottom (18 bolts) <br />582106 OA 1S24 Ignition coil (X3) <br />581957 Magneto - Main <br />581949 3 Magneto - Timing Advance <br />320955 Piston <br />318527 Seat c/w mounting flange <br />317219 Thermostat cover <br />321505 Transom unit (for 3-cyl)
Trent
Re: Evinrude 70hp - Year/model # for rebiuld.
Go to Boatdoctor.com and post your request for John Gervis...He is a Tech at OMC or what was omc..If anyone can help he can..Good luck
