Evinrude 70, '92ish.
David Salter
Not started motor for three years now, it was ok then, but it is now only turning over very slowly even with a good battery. I did see a similar post but I can't find it now. Anyway, I took out the plugs and it turns very rapidly without compression. I think I have checked and cleaned all connections, unless I missed one. Advice would be gratefully received
Honorary Supreme Mariner
Check lower unit gear oil.------pull the starter apart for inspection.-- Very easy to do.
Broken brushes / dirt / check with ohmmeter from commutator to the shaft.
interalian
Also check voltage drop across main cables (+/-) while cranking. Get a buddy to turn the key. You shouldn't see more than a half volt across the cable when it's under full draw from the starter.
David Salter
Thanks for that, ohmmeters an voltage are a bit advanced for me, I'll see if I can get some help.
David Salter
Good result, new battery and it's away. Problem is there's no water coming out the little outlet, does that mean it needs a new impellor?
wrmdunker
To have no water seems odd. A weak impeller should still give a weak stream. Try cleaning the outlet with a weed wacker line or similar to check for blockage.
