Hello , I would like to ask for help. My Evinrude sn:E6RLEOD 1995 6hp is losing power under load. When trolling with about half throttle engine will start shaking , feels like running on one cylinder it keeps running but it has no power , when I put it out of gear it runs or rather sounds fine. When this problem happen and I would open throttle more engine will die at WOT. This would happen in around first 30 minutes , problem sometimes goes away after 30 minutes or 10 minutes and comes back. Engine would start anytime no problem.
Step taken so far: I tested pressure in cylinders - no problem there , cleaned and rebuilt carb twice , checked fuel filter all clean , fresh fuel mixed 50:1, new spark plugs and yes I always make sure pressure relieve valve is open on my tank
I somehow feel like it is ignition problem but not sure where to start. Worst problem is that this power loss will happen only when I am fishing and I am unable to troubleshoot since I don't have good access to engine and I don't want my hands get gas smell, I had my kicker in barrel at home running for 3 hours three times with no problem
Any thoughts? I am going to remove flywheel tomorrow and start looking into ignition part but not sure where to look first. Thank you for help. Rob
