Evinrude 6hp Fisherman
anttman
I recently purchased a really old looking Evinrude 6hp, however it does run really good.Although I would like to find out how old it actually is. Any clues on where i can find a model and/or serial number.
bubbakat
Re: Evinrude 6hp Fisherman
Should be located on the transom bracket or on a welsh plug on the motor. Shiny plug about the size of a quarter.<br /><br />Those are good motors they are a little touchy on the temperature though
anttman
thanks for that bubbakat i found the plate. i hadnt noticed it before because i suspected it had been repainted at some stage. no wi am sure as the model/serial number plate had been painted over.<br />anyway.<br />does anyone know when this model was made?<br />model - 6102E<br />serial - A58610<br />thanks guys, off to work now.
Paul Moir
Evinrdue 6102<br />Year: 1971<br />HP: 6<br />WOT RPMS: 4500<br />Displacement: 8.84 cu.in. = 144.8 ccm<br />Cylinders: 2<br />Weight: 51 lbs. = 23.1 Kg<br />Gear ratio: 15:26<br />Spark plugs: Champion J6C gapped at .030"<br />Fuel/Oil mix: 50:1 87 octane gas (91 RON in AUS) to TC-W3 rated outboard oil. ie, 20ml per l of gas.<br />Lower unit lube: SAE 90W outboard gear oil only.<br /> Picture<br /> From the Old OMC Site.
