ericinmontana
Thread starter- Joined
- Jul 30, 2018
- 3
Hello all. Just joined this great forum today and I thank you for your time in reading and/or replying.
I have a nice old 48 Hydro Swift with a 65 hp evinrude motor from the early seventies (so I was told). She sat for a year and when I charged up the battery, put on the earmuffs and cranked her up she started perfectly.
When i I took it out on the water however, it started fine, and when I started to cruise up the speed, she started skipping and “single clunking” if that’s a phrase. Almost like it was cutting out power. But then it would run and start fine every time if I backed it off and shut it down. So we just “slow boated around”. Ran perfect slow. Then I cranked it up ever so slightly and it thunked again and then slipped out of gear. Sounds perfect still running. Started every time. But it’s like it’s shlioping back into neutral. I’m trying to post a video of it happening if it will let me.
Much help is appreciated. Thank you kindly. Fresh water lakes only in Montana.
