Evinrude 6002B will not run
bowencolton
I inherited a 6002B last time it was out it would only run on half choke.....since then i have cleaned the carb and put a kit in it i can only get it to start and run for about 60sec at a time if starts at all..... i do have fuel going to the bowl the hand pump on the tank is primed as well... any advice would be greatly appreciated.
HighTrim
Sounds like it is not pumping fuel.
If you continually pump the bulb, will it stay running? Could be faulty fuel pump. Is your tank vent open and clear?
oldboat1
will likely want to "refresh" (i.e., rebuild) the magneto if it's been stored -- good bet it needs coils. Replace coils if coatings are cracked. I usually replace points, condensers and wires at the same time. (Would do one side of the magneto at a time to avoid some errors.) I would replace the impeller before running.
typically need an adjustable spark tester, tool for setting spark and points gap, compression tester, and a flywheel puller. (Lot's of info and advice here on tools and parts.) Can use all four tools in testing and prepping. Would check for spark as a first step, and check compression to see what you have.
current symptoms could be fuel pump-related, as described. Just need to be systematic.
Hope you post progress as you go. Lot's of online forum assistance (get world-wide advice!)
F_R
Honorary Supreme Mariner
When you cleaned the carburetor, did you inspect/clean the high speed jet orifice plug? The symptoms suggest it is not clean. It must be absolutely clean with no hint of any dirt or varnish in it. But don't be jamming wires and drills, etc through it. It is a precision part.
bowencolton
Just an update I have cleaned carb again made a lil headway...I believe I have narrowed it to the fuel pump.....I can place fuel tank above engine it will run steady at half throttle but min you engage throttle she dies and if you try tried idle it lower it below half throttle she pops then dies ..... that said if I pump primer bulb fast as I can I can get full throttle and as long as I continue the pace on primer will stay full throttle
Vic.S
If you can keep it running by pumping the primer bulb you either have a defective fuel pump or air is being drawn into the fuel line. Check the connector.. If the O ring is not sealing the connection tightly then this is where air can be drawn in. The O ring is replaceable.
It may be the at the motor end of the fuel line but from what you say about pumping the bulb as fast as you can it's probably an air leak at the tank end
bowencolton
ok new update today..... installed new fuel pump and gasket.... Now boat will stay running on its own but still can not get it to run past half throttle i did try shooting a lil compressed air through the ven on top of the carb this seemed to help it reved up to full throttle... But how do i fix this issue i have no idea where to go Could i have missed something in the rebuild of the carb?
Do you have spark on both leads that will jump a gap of 1/4" or more, yes or no ?
ondarvr
​I'm thinking if you were able to blow compressed air into the carb you weren't on the water, how it runs out of the water or in neutral doesn't mean much, you need to test it in gear on the water.
​You still may have a dirty carb, or it's not assembled correctly, but as indicated, you need to check for spark.
You have to be clear and specific.---------When you say " it runs full throttle " is it in gear or nuetral ?---------Make it clear what you are doing.
oldboat1
Maybe you turbocharged it a little with that shot of compressed air. Interesting.
I'll guess you still have a carb issue. I would start over with the air mix screw. Back it out a turn from seated and see if you can start the motor and warm it up. Then lean out the mix by turning the needle slightly clockwise. If you do that incrementally, the rpms should increase -- likely will want to slow the motor by backing off the throttle. When it's running slow and smooth in gear, quickly rev and throttle back -- shouldn't stall (likewise shifting in and out of gear). At that point, you may be good to go.
If no success, take the carb off and remove the float and idle mix needle, along with the vertical nozzle in the bowl and the hex bolt covering the jet on the bowl front. Soak the carb top and bottom, and everything metal. Finish by blowing out all openings with carb spray, using the plastic wand. It's a good idea to pull off the domed plug on the top before soaking.
Use fresh fuel with a 50:1 mix.
bowencolton
Alright I'll give that a shot I've been running in a barrel just to clarify I've but it in an out of gear same results....played with the air mixture needle.... you can hear a change in the smoothness of idle but doesn't seem to effect being able to run full throttle
It is common for these motors to run on one cylinder !----Post these facts so you can help yourself.-------Compression numbers.--Reason is the factory original gaskets were not that good and current replacements are better with metal rings.------Spark must be able to jump 1/4" reason is if the coils are original they will both be cracked and need replacement.----Note----- I have rebuilt about 8 of these motors in the last couple of years, simple and easy to find the problems with them and every one of them now has new coils.
bowencolton
racerone where can I find a gauge to read compression.....hang in there with me a lil new to the mechanical world and what should the numbers be? Are there still shop manuals for these motors
A compression tester is abourt $40 at any automotive parts supplier.---Can be borrowed / rented too.---Just post the numbers and we go from there.
bowencolton
Also can you tell me is there an evinrude carb rebuild kit? I bought an used the sierra one but there were so many extra pieces due to fitting multiple motors? And would the original cork float be sufficient or should that have been replaced as well?
We suggest you test compression and do a proper spark check.------Then you come back and are focussed on the carburetor -------????
ondarvr
​That's because it only adjusts the low speed circuit in the carb, it will have nothing to do with how it runs wide open.
