Evinrude 6 HP Oil Mixture?
Bob Hossack
Just bought a used motor from an old fella who couldnt find the manual and couldnt remeber the gas/oil ratio. I beleive it is 50:1 but would like confirmation if anyone can help. Modl is E6RENM and I beleive it 1992? Any help would be appreciated - thanks.
casioqv
Re: Evinrude 6 HP Oil Mixture?
Use 50:1 if you can't find any more solid info, as that will certainly be safe. My 1967 6hp uses 50:1, and if anything a motor as much newer as yours is won't require *more* oil than mine. Too much oil = excessive smoke, too little oil = blown engine.
Vic.S
EN are the date letters for 1992.
50:1 is the correct fuel mix
that is near enough 1 pint in 6 gallons
more precisely 2.56 fluid ounces per US gallon
3.2 fluid ounces per UK (Imperial ) gallon
2 mls per litre anywhere in the world except the USA
2% if you are a mathematician
I hoped you knocked good bit off the price for there being no owners manual. Cheap they are not!
