Evinrude 50 Identification
hoglundh
:confused: <br /><br />Evinrude 50 Outboard Motor.<br /><br />I just bought it, it runs great.<br /><br />It is silver, with blue stripes on engine cover.<br /><br />It is a twin cyl engine.<br /><br />The name plate is missing. <br /><br />The only numbers inside I can find are:<br />On the frost plug, C7147524.<br /><br />On the engine 326100<br /><br />On the Carbs, 325343<br /><br />any help would be great.<br /><br />Harold
llfish
Re: Evinrude 50 Identification
Check for an number that starts with 50.........<br />You can check for the year by checking freq. asked questions. There you will find a data base with all the information you will need to figure out the year.<br /><br />good luck
Paul Moir
From the SN I'm guessing 1981 or 82. C711nnnn is an '81 engine, and C715nnnn is an 82.<br /><br />Seems nameplates from around this time fall off a lot.
jimmbo
if you post a picture of it I could most likely tell at least what year the cover is
