Evinrude 4hp
astegall
I bought an older 4hp Evinrude (that looked almost new) with a sticker on the top that says 50:1 mix. It starts and runs great for about 1/2 hour then dies and will not start again. It has been to two outboard shops, the carb has been rebuilt, the impeller replaced, an ignition part was replaced and each time it was pronounced fixed, but the result is the same: it will run great for 1/2 hour, then die and will not start again. Any suggestions are welcome.<br />Thanks<br />Allen Stegall
OBJ
Re: Evinrude 4hp
Hello Allen...welcome to the fourms....<br /><br />Allen...you didn't post a year or model number so I'm going to take a chance and say you probably have a CD type ignition (no points or condensers). The problem sounds heat related. That dosen't mean the engine is over heating....at least I hope not....but while we're here, are you sure the engine is not over heating? You should be able to put your finger on the flat area above and forward of the head for a few seconds with out jerking them away.<br /><br />If your engine has a power pack, the engine may be giving off enough heat to cause it to cut out on you. A way to find out is, wait till the engine is cold. Run the engine in a garbage can full of water (make sure the water level is well above the lower unit). Take a hair dryer and blow hot air onto the power pack. If the engine quits before long, this probably is the problem.<br /><br />This all of course depends on if your engine has a CD ignition. <br /><br />Please post a year or model number for us. Thanks.
Joe Reeves
Re: Evinrude 4hp
As OBJ states, without a model number, we're sort of shooting in the dark so to speak. However, if the fuel tank is attached to the engine, check the vent and fuel filter. If the tank is portable, check to make sure it's vented.
astegall
Re: Evinrude 4hp
Thanks, I looked themotor over trying to find a model or serial number - I will take a closer look. The last time I ran it and it died I put my hand on the top and it did not seem excessivley hot. Plus, it has happened so many times now if it was overheating it would seem like the compression would be gone by now but when it runs it runs great and will push my 3000lb sailboat at five knots. I'll try the hair dryer trick.
OBJ
Re: Evinrude 4hp
Allen....look on the port transom bracket for a plate with the model and serial number on it. Or, on top of the block there may be a large freeze plug with the same on it.<br /><br />Thanks.
