Re: evinrude 48 compression help
If you do the test exactly as described in the Top Secret File ^^ you should get 100psi or better with both cylinders within 10% of each other.
Remember, psi is not the main issue, matching the cylinders is. The main exception to this is when you have a head gasket failure between the cylinders, then they may both give you 40-50psi.
