evinrude 40hp lark 1968 water pump trouble
R.Johnson
Re: evinrude 40hp lark 1968 water pump trouble
Evinrude Boater: There was a OMC service bulletin on this in the early years of these type engine's. The cracks' can cause the condition you discribe. Did,nt we discuss your engine in an earlier post, with some idea's on how to fix it?
K.B
Just now read the post. I have a 71 40 hp ev. that I had trouble w/a couple of yrs. ago when it was new to me. May not have a bearing on yours but sounds familiar to me. My head gasket was blown and would NOT pump water. Wrench told me to check the compression and see if the gasket was the problem and sure 'nuff. Replaced and been @ 110 on both cyls. ever since.
Just for the fun of it all, check.
K.B
Oh yeah, mine has no thermostat so I know nothing about that kind of problem. "Flathead" so to speak!
R.Johnson
K.B That certainly is not out of the question, it certainly seem's to be a puzzle.
Evinrude Boater
You're right R.Johnson, mine has a few cracks and I think I will JB Weld them.
redsmufc
i have put the pump back together today there was a crack in the thin wall near the selecta rod i have jb welded it, sealed the impellor plate down.
do i need to use sealant between the pump housing and the plate?
fingers crossed going to test it tommorow. all going well
samo_ott
Is the impeller key there? It was mentioned but there was no confirmation?
I'd test the LU in a bucket, that will isolate the problem.
redsmufc
yes the impellor key is in place. is there a easier way of testing the lower unit without using a 3/4" chuck drill??
samo_ott
My LU's are smaller (18hp and down) and a 1/2" drill fits em all. Not sure how to turn yours at 5/8".
Evinrude Boater
If you have a small belt you can likely loop it around the driveshaft and put a rod in your drill to do the same. A pulley on the end of your drill would be even better.
redsmufc
many thanks for your help i'll give it a go
K.B
Ever check the compression yet? Don't rule the gasket out!!
redsmufc
Tested in drum today pumped water for a while then stopped it did throw a lot of water out of the drum the level dropped about 2" would that cause it.
HighTrim
It will pump until the water pump is no longer fully submerged.
redsmufc
hello thanks for your reply, water pump is still submerged must be a problem again!!!:mad: thanks again
tashasdaddy
the leg has to be submerged 1/2way up. the pump is not self priming.
