Jackie1234567
Thread starter- Joined
- Oct 19, 2015
- 2
Hello,
Me and my friend are working on a little project of ours and it involves an Evinrude Big Twin engine 40 HP.
We bought it cheap and tried to get it running. So far we've only managed to let it run a few times, and every time it runs for a couple of minutes, it tends to loose power and eventually it cuts out. We've already checked the ignition, and we believe it should be fine. We don't think its a fuel pump problem, because if we squeeze the pump ball in the gas, it doesn't improve the running. The only thing we can tell for sure is that it starts fine when he's cold, then sometimes runs a few minutes pretty ok, but after a few minutes full speed it drops down. Could it be that this is an air leak somewhere? Does anyone had such a problem allready? The problem is a little bit that we don't have any true knowledge about outboards, we do have a little about two stroke engines... We live in Belgium, also not really a boating country :s. But we have faith in that old Big Twin, because when it goes, it really goes!
Could it still be ignition or fuel pump? Any suggestions are very appreciated!
Grtz!
Grtz!
