evinrude 40 hp
mikeal
Can someone help me i'm trying to remove the gear set from the lower unit of a 87 evinrude 40 i've got it down to the top shaft and rear gear but can't remove either. Any advice would be greatly appreciated. The clutch dog and the rear gear set and top shaft are bad so i've got to pull them.
F_R
Honorary Supreme Mariner
Re: evinrude 40 hp
By "rear" gear, you mean the forward gear in the nose of the gearcase?
I'm not totally familiar with that exact model but the useual procedure is pull up on the shift rod to put it in forward gear, that gives access to get the pinion nut off. Then remove the bolts holding the drive shaft bearing housing and pull the shaft out. It may take some persuasion to unstick it from the taper in the pinion gear.
Then you can remove the pinion gear from the housing. Then remove the bolts holding the shift rod cover, and unscrew the shift rod from the detent and remove from the housing.
Then the prop shaft and shift mechanism will pull out of the case.
Or, at least something similar to this.
mikeal
Re: evinrude 40 hp
Thanks so much i will try tomorrow afternoon this thing is kicking my butt. But this forum has been a life saver for sure you fellows are a great source of info to say the very least thanks again.
Mikeal
