Re: Evinrude 4 hp 2 stroke problem. Updated with pics!
I managed to swap the pin out and installed the made from metal instead, problem is, with the float turned the way it looks on the schematics and as you guys say it should be fitted, it isn't even possible to mount the bottom of the float chamber on the carb. So I guess either is this a European version on the carburetor or could it be that you might remembering it wrong?
Lenard, that would be great! If you could send me an E-mail
robbin.oberg@telia.com I could send you the part numbers so you could check if you could get your hands on them and calculate what is will cost to ship the parts to Sweden.
From what I can tell there's no problem with the flow of the fuel, when I open the fuel valve it pours out fuel at a good rate, and I'ts the same if I disconnect the fuel house from the carb it pours at the same rate, anyway, thanks for the tip! =)
