frustratedboater
Thread starter- Joined
- Jul 10, 2007
- 503
Greetings all,
I routinely fired up one of my recent restorations, an Evinrude Lightwin, 3hp, and noticed that the exhaust plate had discolored the fresh paint job.
Last winter I had the block torn down I had made sure that all the cooling ports, water channels, were clear, really taking my time on this. The impeller is fresh and everything is to spec!
One test I did perform was taking the flush plug out and ran it to see the pumping action if any. It shot a 6'-7' stream out! So, the pressures there! On the other hand the exiting water spray was nothing to be impressed with. Just a little spray out the plate.
Do these engines run that warm, to discolor the plate (ran about 3-4 minutes to set the idle)? Should there be more of a discharge of water out the plate?
Need your advice on this one...
~FB~
~FB~
