evinrude 35 slow turn over when starting
jsmelley
Evinrude 35hp long shaft w/ electric start.<br />Very slow turn over when spark plugs are in.<br />With plugs out, turns over fine, exhausting through exhaust ports. Put plugs back in and will barely turn over.<br /><br />What gives?
backdraft
Re: evinrude 35 slow turn over when starting
jeff, check all battery cable connections. I would have to sat that probably the starter is drawing to many amps because it needs rebuilding. Turning over easy is normal with the plugs out. nevjb
R.Johnson
When you check out all of your connections, try flexing your battery cables up close to the engine where they flex as you turn the motor. I recently had a problem like yours, and the positive cable was nearly parted at this point.
Cricket Too
I know I'm stating the obvious but you should always troubleshoot the easiest first. Is your battery good, fully charged, possibly a dead cell or dirty on the posts? Could be the easy fix. Good Luck.
