Evinrude 30hp early 90's - Low Speed Needle Housing Query
OMC_Rookie
Hi guys, I've been a reader of this forum for some time however have only just gotten round to signing up.
Would like the opinion of those in the know as to whether I have an issue or not.
I'm concerned about the condition of the brass low speed needle housing (not sure if this is the correct term). It's basically the brass bush that the low speed needle is screwed toward in order to control the Air Fuel ratio at idle condition. The carburettor is a Type 'A' from a 1992 Evinrude 30hp.
Low speed idle quality has always been an issue and the ability to make much improvement with the low speed needle has been limited. It appears that the brass bush / housing in the photos attached has been worn? Or it could be the case that this is the shape of the factory part. I pulled down my old 25hp evinrude carb of similar year to inspect. The 25hp carb has a near perfect inner circle for air flow whereas the 30hp appears to have a gouge out of bush. Is this a factory difference between the two size outboards?
Happy boating
  • IMG_20160104_181047 - Copy pdf.pdf
  • IMG_20160104_180740.pdf
  • IMG_20160104_181147.pdf
OMC_Rookie
After more research this still has me puzzled. Does anyone have a 30HP Type "A" carb that they would be happy to unscrew the low speed needle and take a photo? Thanks
oldboat1
? Aren't you missing the low speed needle, or am I missing something?
OMC_Rookie
Hi Oldboat1,
In the first and third photo I have the low speed needle removed from the carb. The second photo shows the needle still installed.
My concern is about the condition of the brass bush (1st photo) being that it looks like there is a gouge in it. I found on a 25hp carb that this gouge does not exist. So am trying to confirm whether all 30hp carb's have this from factory? or is this from wear.
oldboat1
OMC_Rookie
No Title
Sorry Oldboat my description of the photos were in the wrong order above
photo 1 and 2 are with needle removed, photo 3 is a pic of the complete carb with needle screwed back in.
Yes it is the orifice I am concerned about. Yes I do have the needle assembly I've attached a photo of the needle FYI.
The motor has always struggled to run well at low rpm despite low hours/use. I'm thinking this may be playing a significant part of the problem. Yet would hate to try purchase a new/2nd hand 30hp carb and find that the orifice comes like mine from the factory :s
oldboat1
well, the orifice should be similar to the one you describe on your 25 (symmetrical). A replacement carb or carb top may be needed.
