shipwreck
Thread starter- Joined
- Nov 23, 2006
- 263
I have 3 wire tilt motor for the 1970 , i need to troubleshoot. it is wired up directly the battery and dose not work.. it make sounds and dose not move when power is applied by using the switch in any direction. i have 12v a battery and other systems on the boat work. the switch test good use meter (beep)
in both direction.
low/ no fluid in motor will it cause not to work?
Dose anyone have a good readable schematic? FOR 3 wire tilt motor?
Dose this 3 tilt system require solenoids? or can you hook up directly to the battery?
looking for the next step to troubleshoot
thank you
in both direction.
thank you
