Evinrude 2hp Mate runs then dies
cajuncook1
Re: Evinrude 2hp Mate runs then dies
Does water come out of the exhaust relief ports ( usually a thick mist )? I know you stated that the water pump was replaced, but is it cooling the head? Did you get a cylinder head temperature with a laser temp meter? If the head gets hot it can cause the issues that you are having. It is better to be sure your not have a cooling issue, because ever time a motor over heats and kills, it is causing damage to your cylinder and pistons. (The overheating causes the rings to expand, score and damage the pistons and cylinders)
I am not saying that over heating the is the definite cause of all your motors problems, but please make sure your motor is not overheating and causing damage.
The coils, if going bad, can cause problems after the motor warms up and then gives out. When it cools, then it starts functioning again for a short period. It is not hard to change the coils, points, and condenser. If the coil is bad, I would say change the points and condenser while your in there(they are cheap enough).
Look at the iboats links I originally supplied, they have links for removing a flywheel, checking the coils, points, condensers, and how to set your points with a feeler gauge.
You will see a lot of experience guys ask about compression, spark and fuel. (They are using a systematic approach to diagnosing an engine problem or problems....in this order)
C= compression ( if your compression is low are uneven between cylinders >10% then others checks don't matter until the that is resolved)
S= Spark (if your have problems with your ignition then you can have the cleanest carb and great fuel delivery but it will run bad or not at all)
F= Fuel (if your carbs are not clean and fast/slow idle needle are not set right then it will run but like crap. If you have it set too lean then you run the risk of poor fuel/oil delivery and damage your pistons and cylinders then you run into the problem of C (poor compression from damage).
So it is advisable to get a manual for your motor. Excellent resource, specifications, and diagrams. :cool:
The reason I am jabbering like a monkey on crack, is a lot of times we naturally wanted to get it fix fast, quick and easy, so we neglect doing do diligence on our motors. Also if your new to working on motors, like myself, it can be very intimidating taking things apart and fixing them. That's where the service manual, links, good advice from the experience guys on this forum, and patience pays off. When you learn how to take care and fix your motor it is cheaper in the long run, you keep your motor up and running longer and better.
Hope you get your motor fixed soon and on the water!! (mmm....I smell the fish and shrimp frying already):D
cajuncook1
CMIYC
So I began working on it and heres what I have done so far.
-checked fuel rate to carb
-replaced spark plug (original was only gapped at .010. Might have played some part)
-completely disassembled carb and cleaned it out. Inside it looked real good besides the fact that more dirt came out than what comes out of my shoe after a day at the beach.
-fresh fuel
I took it out this morning and....... still dies at high rpm. :confused: Played with the mixtures and still the same results. So next step is taking off the flywheel and digging into ignition. If that doesn't work, I think I'm just gona set the motor on fire and walk away. Oh, and I know the info is probably somewhere in this site but can anyone give me a good site to get parts for this motor? My local shop has to order everything for it so I figure I'll save myself the time and just get it online. Thanks again for all your help guys. Its much appreciated
CMIYC
Oh and I don't know if this matters but when I took the carb apart I noticed these missing. If you look on the diagram, it calls for 2 #30's on both mixture screws. I have only one on each screw. Wasn't sure if that affected how the screw sat.
Harrington61
If it's ran by a VRO2 pump... its bad, replace with regular fuel pump.... same problem I am having... Mechanic is going to fix it next week.
dan279
Hey everyone. I have been a long time lurker of this site and finally decided to become a member today. I am having an issue with my evinrude mate. I have searched this site and others and still can not figure it out. I just recently bought this boat with the mate, so its new to me. Basically what happens is the motor will run fine for a while, usually at half to 3/4 throttle. Then when I run it at a faster speed for about 5 mins, it just dies. Then it has a really hard time starting back up. If it does start, it runs like crap and I have to keep playing with the choke to keep it running even though its hot. I dont get it. It sounds like a heat issue but I don't know.
The previous owner just had the carb rebuilt, new points and condensor, plug etc. All with less than 25hrs. The gap on the plug is fine and the jets are where they should be. Fuel/oil ratio is also correct.
Can anyone help me out? This is really putting a damper on my fishing season. The motor is slow enough as it is. I hate to only run it at half throttle all the time. Thanks so much everyone
I am having the same problem.Tuned up, new carb rebuild with needle valves, new gaskets and needle valve packings, new coil, new pump impeller, new shaft seals...same problem......motor dies after about 2-3 minutes of run time. I will replace the impeller housing cover as it is scored somewhat, but I suspect an overheat problem. I can touch the cylinder with the palm of my hand after the engine has stopped.....feel warm.....that's about it. ANY MORE IDEAS? IT IS A 71 MATE IN VERY NICE CONDITION. The carb was extensively rebuilt....new everything, except the main jet. Needle valve settings initially...1 1/2 turns from seat high and low speed.
dan279
My next step is to replace the reed valves and springs in the intake manifold. They may be worn, such that at higher RPM they do not function properly. Hey I am no sloutch, I'm an A&P mechanic trying to get some fishing in. Checked all the obvious too.
dan279
The reed valves fatique.....that's the problem. Buy em at boats.net
