Evinrude 25253r ignition points questions
flyingscott
I will try to explain it to you. It has to fire before TDC because it needs enough time to burn and produce the work needed to push the piston down. If it fired 3 degrees after TDC your combustion is wasted out the exhaust port. The combustion process needs to happen between the ports opening so you need to start the combustion process before TDC. Your motor is not firing at TDC you set the points at full open at TDC the cam the points ride on is the timing mech. If you took a dial caliper and a Multi meter and actually checked the timing you would see when it actually fires. Another part of the equation is the flywheel which is where your timing all starts. It starts when the flywheel magnets come around and cross the pickups that's why the key is so important.
I do not have time to explain it all in detail but most motors fire at around 20 degrees BEFORE TOP DEAD CENTER at full throttle !!
F_R
If you look at your motor, you will notice that the magneto armature plate rotates as you advance the throttle. When it rotates, it changes the spark timing related to TDC. So at wide open throttle the spark occurs considerably before top dead center. At slow idle position, it probably occurs after top dead center. How much it varies is fixed by design and is not to be monkeyed with, nor can it even be monkeyed with without re-engineering it.
Now back to those points: The purpose of setting them is NOT to set the timing in relation to TDC, although yes it does affect it a bit. The purpose in setting the points is to make them open at the right time as the flywheel magnets pass the coils' laminated cores. Therefor, any reference you may see concerning timing is about timing the points in relation to the magnets, NOT in relation to TDC.
Don't try to make it complicated. Adjust the points so they open .020" at their widest opening and let it go at that. That's "good enough". If you want to get them perfect, and easier to do, you can use a timing fixture made for the job. But after reading through this long thread, I think "perfect" may be a bit of overkill.
webbrs
Thanks for the replies. Racer, you make me laugh. So glad you could make it to the party.
And yes some of these threads / posters make for better reading than comic books.
