thatone123
Banned
Thread starter- Joined
- Mar 7, 2009
- 707
This site makes me get a new password every time I try to log in. Anyone experienced this? My outboard problem is that after half a winter and so much time wasted ordering small parts, gaskets and special tools I finally got my E-tec 250 lower units together. The shop manual said that the M-2 LU's prop bearing carrier had to be pressed into the gearcase, so not having a press I took them to the Evinrude dealer. They told me that the counter rotation LU locked up when it was pressed. They wanted more $ to solve the problem and I will have spend $500 on these units already, so declined. The gear set at the rear of the unit screws into the case and you need a special spanner wrench to tighten it which I did not have so I used an automotive rental spanned to somewhat tighten it. When did this I tore one of the 2 shims. They both did not seem tight to begin with and I did not replace them but left them out. Do you think this made the LU's lock up? I know it was foolish not to replace them but it seemed they were not needed as they were not doing what shims are suppose to do, but just floating loose.
