Evinrude 25 Carb adjusting
jsmxlove15
Hi guys this I actualy my first post on here :) anyways Ive got a 1992 Evinrude 25 with a tiller. This is the first boat I've ever owned so I'm kinda a nooby and 2stroke boat motors! I took it out the other day and it started up pretty easy but while its idling it sounds like it backfires or somthing and will kill the engine.. After it gets warmed up I don't have to much trouble with it though. And I've noticed that a good amount of oil comes out of the front of the carb I mix my gas 50.1 is that normal? Another thing I've noticed just looking at it off is that the butterfly dosnt fully open.. At full throttle it just cracks open about 1/8" is it supposed to open all the way? If you guys could give me some tips that would be great the motor runs good just want to work the few little bugs outta it :)
flyingscott
Are you leaving the primer 1/2 out when you let it warm up? The throttle will not fully open unless it is in gear. Oil coming out of the front of the carb is normal especially if you tilt it up.
jsmxlove15
I usually start it with choke and then push the choke in and give it some throttle or it dies.
Newyota
I got one similar to yours,but older you should check your link and sync adjustments.They may be off.Butterfly sounds way off position.Should be open.
jsmxlove15
Ok do you know where I could find all the specs and how to do it I downloaded the Manuel but it's kinda confusing to me I like pics lol
flyingscott
There is NO choke on that motor only a primer, to start you pump the primer twice and leave it 1/2 out to warm up push it back in after it warms up. Is it in neutral when you try to open the throttle. Those motors have a throttle stop to prevent overrevving in neutral it drops away when you put it in gear allowing full throttle. Do not do a link n sync until you answer the neutral question. Since you say the motor is off (not running) when you look at it I am assuming you are in neutral so what you are seeing is normal. I have the same motor in a 93 model. You can also try turning the fuel mix screw out 1/8 of a turn.
jsmxlove15
Ok yes it is in neutral when I looked at it. and I just figured it was a choke 😁 maybe that will help with the starts!
jsmxlove15
Ok so I ran it again an it still back fires and about stalls out ever once in a while even after it was fully wormed up! I have a vid of it but I'm not sure how to put it on here from my phone..
RCO
Sounds like you are describing a lean sneeze. You can try to turn the mixture screw out a bit as recommended above. It is also possible that your carb is dirty and needs to be taken apart and cleaned. Try the mixture adjustment first. Is the motor getting up to temp? If the thermostat is stuck open the motor will stay cold and not run right. That motor should be fully up to operating temperature in well under a minute.
jsmxlove15
How do I know if the it gets up to temp? It gets to hot to touch... And yes I will try turning the screw out a bit! :) thanks!
oldboat1
If too hot to touch it's too hot (top of head). The water pump impeller is usually the culprit, but could be a thermostat issue (or both).
Normal operating temp is in the range of 120-140F. 160F is overheating.
jsmxlove15
Ok so I checked it and left it idle until it was fully warmed up and it stayed right around 140* I also turned the air screw out a bout a half turn and it didn't sneeze any more! It's running good thanks to all you guys! :)
jsmxlove15
One last thing tho the starter has trouble engaging sometimes have to push it a few time before it will engage is there any easy fix to that?
oldboat1
The starter gear doesn't engage? (i.e., doesn't pop up and engage the ring gear on the flywheel?) That could be a wire connection or low battery (or solenoid, starter brushes, key switch....)
Would first clean battery connections first until bright, and charge battery.
jsmxlove15
Ok I'll try that didn't know if it was the starter or somthing els.. I did see that the battery terminals were pretty corroded!
oldboat1
yeah, simple fixes first. Glad to hear you got the lean sneeze handled -- 140F is good.
jsmxlove15
Yes that was bugging me pretty bad :) I got it in a barrel so I can run it and when I give it full throttle in neutral for just a second and then let of real quick it kinda lopes down to an idle is that normal or should it be smoothly stopping?
AlTn
wot in neutral not a good idea...if it goes back to idle w/o the engine dying you should be good to go
