supergoose
Thread starter- Joined
- Aug 24, 2003
- 4
I have a 89 evinrude 225hp on a 21ft daytona, the tilt & trim motor will not go up. I was running and the motor just went all the way down, and would not come up. There is fluid leaking from the bottom right support rod/piston. It is leaking around the outer ring, is that a seal problem, and is it very hard to change? Is there anyway to fix this, I manually hand jacked the motor up and it is now locked in the up position.
