Hello and thank you for reading this.<br /> I have a 1997 Evinrude 200 Vindicator. I had a new reman powerhead installed in Feb. '05. From the day I got the boat back, I have had problems. It is in the shop again as we speak. It has been in the shop 8 times this past fiscal year. The main problem I am having is that at WOT, the water temp alarm goes off and it goes into SLOW mode. I'll shut it down immediately and let it idle for a minute or so. Most of the time when I do this, it will idle at 2000-2500 RPM's! To get the idle down to normal, I'll push in the choke. Let me back up a little. Last week I took my mechanic out for a spin, trying to get it to overheat for him. We weren't sure if it was actually the overheat light and alarm, or the check engine light and alarm, so we did this to be sure.<br /> When cruising at WOT, he was watching the water pressure gauge and the tach. Water pressure was at 49 PSI. Pretty high. The tach was at 5600. Here is where it gets weird. After a few miles, the RPM's slowly creeped to 5700 RPM. Then, slowly up to 5800 and stay there for 30 seconds or so. Then, it rapidly jumped up to 5900 for a few seconds, then it jumped to 6000. This is when the alarm sounded. We took a brand new fuel pump out to the lake to install after running the old one to see if this was the reason for the overheating. We loaded the boat and pulled out of the lake, popped off the cowling and noticed quite a bit of water all around the base of the cowling. There were even drops of water half way up on the block. Not good. I don't think there was anyway that water came in from around the cowling. It has a very good seal. The breathe hole is on top of the cowling, but no sign of water entering this area. We then felt all over the block. It was warm but not hot at all. Thinking that there was a water leak somewhere due to a bad seal or too high of water pressure from a waterflow blockage, we decided NOT to install the VRO pump at this time.<br /> We then drove back to the shop and pulled the block off and the heads off, looking for any possible water blockages. None were found and the gaskets looked good. We did see the in the head, the #2 and #4 cylinders were completely covered with a dark brown to black, very sticky residue. The mechanic thought it very much resembled burnt or boiled oil. The #6 cylinder head had only a few drops of the very same residue. The #1,3 and 5 cylinder head looked normal and very good.<br /> I have had the thermostats replaced, the water pump replaced and a complete carb overhaul done in the past few months. I am in dire and desperate despair. I know it has to be something simple, but we can't finger it. I sincerely appreciate your time. I appreciate any input you may have. We are scratching our heads. Please, please help me. <br /><br />Sincerely,<br />Don Cary
