CPO Hazard
Thread starter- Joined
- Sep 15, 2016
- 10
Been a while since I've been on the forum. I've still got my 1972 Evinrude Fastwin 18hp 2-cycle. She has been acting funny lately. I can troll forever, but no matter what the throttle setting has been while running, if she's been running for 20-30 minutes, and I go WOT, she will lose power, bog down, then shut down. It doesn't matter what the throttle setting has been. If she's WOT right out of the ramp or trolls for a period and then WOT, 20-30 minutes of running, and she does the stall dance always in WOT. I can sometimes drop the throttle fast enough to go to trolling speed and save the restart. I usually have to wait for a little bit before she starts back up if she stalls out completely.
My first thought was that the fuel system was the problem, because the primer bulb was hard to pump after the shut down. Venting the tank didn't help. My next thought was that the spark plugs were the wrong model number; good at trolling, not good for WOT. She runs at idle and trolling speeds all day with no problem.
I have rebuilt the carb, replaced the spark plugs twice (trying two different models hotter vs cooler), replaced the entire fuel line and fuel pump, and replaced the thermostat. The problem is still there. Maybe the thermostat is defective?
This was a problem before I did all the replacements, and still is now. I do all my own maintenance after doing exhaustive research. So, I'm trying to get ideas for what I can do. I've lost faith in marine mechanics. Of course, this motor is almost as old as I am, and she may just be hitting her end of days.
