1995 model is very likely to have SLOW. Look at temp sender in top of head. If it has two wires, one tan and one white/black, it has SLOW.
You have a bad roller in the slot of the cam. The marks will never line up with that bad roller. The carb roller looks OK.
The link and sync process on this motor is odd. You should get a factory service manual before you try and linkage adjustments.
For example, the short rod that attaches to the timer base is adjusted by LENGTH first. And that length is determined by the model number.
Oftentimes, you can get the motor to run right, and the marks will not line up like the book says. Don't freak out if the marks are slightly off when you have it the way you want it.
In your video, the engine seems OK to me. I cannot hear a problem.
