Evinrude 1995 40hp charging/water issues
Tommyaleks
Hello all. I have a Evinrude 40 hp 1995 mod with a electric start. I have a couple of question regarding this outboard. I hope someone can tell me what`s going on.
first on my list is the charging system. When I measure the volt on the battery it show me 12.6 v, as soon as I start the engine it raises up to between 17v and 20v, when I turn the engine off the voltage drops to 12.5v. The battery is fully charged, it`s not new but not to old ether. it`s from a car and are about 60 amps. I have found out that I have a regulator on this engine. it`s 5 wires on it. 2 yellow, 1 purple, 1 grey, 1 red. I did some test.
With the regulator on the table and the multimeter set to diode/Ohm I got his.
Both yellow to red wire show 592 in one direction.
Yellow/grey to ground was 80 ohms
yellow to ground was 157 ohms
Grey to ground was 10k
Grey to red was 182 ohms
Grey to yellow/grey was 129 ohms
Grey to yellow was 92 ohms
I have a dva adapter but I`m not sure what reading scale I should set my multimeter on. So I have not testet with the engine running yet.
I tried to do that but my multimeter was all over the place. I think my regulator is bad but I am not sure.
The other problem is the cooling system. I just changed the water pump and all the seals in the gearhouse. The water flow is strong now and it`s cooling fine. But is it normal for water to get out between the outboard leg and the gearhouse? it`s not all the way round but, only in one small place, near the gear rod or something. is this something I should take care of?
Thank you guys.
wrench 3
How many wires do you have on your voltage regulator? Are there two reds? And what is your engine serial number.
Tommyaleks
it`s all written above. I have fixed the problem now, it was the regulator.
