evinrude 1989 tach
seaslick
I have a 200 hp 1998 evinrude outboard and the tach stays stuck on about 2000 rpms when moter is not running,could anybody help,thanks,seaslick
psteurer
Re: evinrude 1989 tach
Does the tach reset itself to ZERO when you turn the key on? If so, remaining at some other position other than zero is normal for a tach when you turn the engine off. I am assuming the tach works correctly when the motor is running.
seaslick
Thanks I will check that when I get home and let you know when I can,thanks again!
