Evinrude 1989 30HP - problems on restart
ccie5364
The cold motor starts up with out any problems and will run WOT nice and clean, no problems.
After running WOT for 5-15 minutes, and then letting it idle for 5-10 minutes, it will start "bucking/surging" when trying to move to WOT again. It will run at low RPMs just fine but only starts the 'bucking/surging' when trying to move to WOT.
Steps go like this:
-starts fine
-run fast fine
-run it for about 5-15 minute fast and then stop. (not turning the motor off, just going to nuteral. however, the same thing happens even if i do turn it all the way off).
-start pushing on throttle to go fast
-starts bucking/surging.
-let it sit ideling for 3-10 minutes
-it will finally start going to WTO again and runs great.
-repeats over and over. Almost every time i run it WTO and then go to idle for more than 5 minutes, it will start the bucking.
I have replaced the fuel filter.
I have tried: squezzing the bulb, putting it in reverse, reving-up the engine with the Warm-up lever, any many other things like crossing fingers.
Nothing seesm to matter other using the Warm-up and reving up the motor does seem to clear the problem quicker.
Any ideas:
-gasline is old but looks good and no leaks when squeezing bulb
-fuel tank holds pressure when not running
-idle is nice an smooth and it runs great expect for this problem
help and thanks
boobie
Sounds like you have an ignition problem. When did you last replace the spark plugs ??
AlTn
if you find this is an ignition problem < a timing light on either spark plug wire while observing the flash for misses >, use the Search function at the top of the first Forum page and study up on the UFI Ignition System...then go to cdielectronics.com/troubleshooting...find your ignition and follow the steps to diagnose
ccie5364
Thank you for the responses.
I will start with figuring out if it's spark/fuel.
I will check the tank/fuelline/sparkplugs/etc.
I had someone tell me it was a powerpack, but I'm confused on how that would make it Buck/surge.
I won't have ti out of storge until March so i will not be able to update until then.
Thanks again!!!!!
Bosunsmate
Have a look at your plugs, one may have a bad discolouration indicating which cylinders to blame
ccie5364
I will follow the recommendations. I am confused on how a bad sparkplug would work great, then cause the surgging, and then start working again.
Note that I'm trying to learn as well as fix the problem.
thank you again for the help.
macsailor19
I had similar problem on '89 48 hp. try disconnecting tan wire to temp sensor on top back or engine. this disables SLOW over heat protection that limits speed might be the problem.
