Evinrude 1978 35hp Bendix malfunction?
ScottDC989
Searched everywhere and couldn't seem to find anyone else with a similar issue. My starter bendix engages the flywheel, the starter motor keeps spinning, but doesnt turn the flywheel. I took the bendix off and the flywheel gear end of it spins on the starter screw end of it. Always thought these were one solid piece. If it is truly supposed to be one solid piece can i weld it back together? it doesnt feel sloppy, just seems to have a drag to it
Joe Reeves
The starter bendix is NOT a one piece unit...... it has a clutch within it to absorb shock. The clutch is slipping withing the gear assembly. The cure is to install a new bendix.
ScottDC989
What is the proper way to install the new bendix? I had a hell of a time getting that nut off without spinning the starter
Joe Reeves
The proper way to install a starter bendix is to lightly (very lightly) grease the spindle of the armature, then clean the threads of the armature with either lacquer thinner or acetone, install the bendix assembly, put a drop of loc-tite on the threads, then install the nut using a hand held air powered impact wrench. Now, let it set awhile (10/15 minutes) for that loc-tite to seal.
That'll keep that nut from spinning off for a few years.
