Once it starts, can you keep it running by squeezing the bulb? If so, the fuel pump, or lines would be implicated. ANY air leak anywhere in the lines between the fuel pump and the level of fuel in the tank will admit air bubbles and keep the pump from working. Also, there is a practical limit how high the pump can lift the fuel. So, you took the fuel pump apart?? Is it the 2" square pump? Hm.m.m.m.m.
