mottt
Thread starter- Joined
- Aug 25, 2009
- 80
I have bee trying to get this thing running for the past couple of weeks. I first had a wiring harness that was cut, then a solenoid that needed replacement, a carb that needed to be rebuilt.
I finally completed all this and attempted to start it.
I primed the gas and I could hear the carb bowl fill and the primer bulb got tight. I have the low speed needle turned out 1.5 turns. and there is no high speed. The starter spun the flywheel, healthy! I did not get a sputter or any indication the motor was trying to run on its own. I tried starting fluid (i know), only once to see if it would fire, and it did for a second!
Spark gap can jump a nice blue arc .5 inch on both wires.
I have new gas
Everything is pointing towards a gas / carb problem. Now when I said above that I rebuilt the carb, thats not entirely true. I removed the carb, needles, and seats. I cleaned all passages and parts. I did not have a rebuild kit. So I reused old parts. NOW, I know this is prob the entire issue, but can someone explain why? It kinda makes sense to me that doing these steps would make some kind of difference in the starting results. But of course it did not. I am confused and hoping someone can explain why rebuilding the carb with new parts versus used parts would not help with starting. (even though all passages are cleaned out)
I have new gas
