evinrude 18 fastwin shaft urgent!!!!!!
burton15
whats up everyone i got a 18 hp evinrude fastwin and i took the lower unit off where the impeller is and i pulled down on the lower unit and checked the impeller and it was ok when i put it back up and put the bolts on i put it in a dunk tank and tried pulling the cord it was extremely hard to pull so i took the lower unit off again but then the cord pulled fine ad i checked the recoil and thats fine whats the problem? could you please email me with the awnser my adress is burtonbalance15@hotmail.com
Spidybot
Re: evinrude 18 fastwin shaft urgent!!!!!!
You must have assembled it wrong. If it turns easy with the lower unit off and hard with the lower unit on, your lower unit adds a lot of friction.<br /><br />Means that some moving part in LU is getting jammed when you tighten the bolts.
Walker
Try to turn the drive shaft by hand when you have the lower unit off. I suspect you pinched part of the impellor in the housing. Walker
