evinrude 15hp loose propeller
dozerdozer
hi everyone :) a new friend of mine has an evinrude 15 hp outboard motor, it has a loose propeller, I was hoping someone here could give me some suggestions on which direction to point him in repairing this. He isnt very computer friendly, so thought I would do a little searching to see if I could fine some help. He has really helped me out a lot, I would like to return the kindness a little *s............thanks so much..........heres what I could find on the motor.......... 1975 Evinrude 15 horsepower
Serial # 15504C
Model # 0009262
BoatBuoy
Re: evinrude 15hp loose propeller
Please be more descriptive than just asking about a loose propeller. Is it loose on the shaft, is it loose from it's hub, is the prop shaft itself loose, etc?
ezeke
You must have a thrust bushing behind the propeller and a thrust washer in front of the propeller.
Go the the BRP Parts Catalog site and look up the motor, then look at the gearcase diagram.
http://epc.brp.com/default.aspx?brands=ej&lang=e
If you run the motor without the thrust bushing, you can severely damage the gearcase.
dozerdozer
Thanks a ton for the web site addy, shows a great view, I'm off to go help my friend, I'll let you know how it turns out *s
