steviecops
Thread starter- Joined
- Oct 3, 2003
- 585
Hi<br />Is there a way to remove the cylinder head from a 1984 Evinrude 15 without first removing the powerhead?<br /><br />The problem bolt is the lowest one on the left as you look at the head. I've tried removing two rear mounting bolts, (one on each side), but the pan doesn't drop. I only need about an inch! So frustrating to think I might have to remove the powerhead just to put a helicoil in the bottom plug hole!<br /><br />Thanks in advance.<br />Steve
