Evinrude 150hp VRO lower unit removal shift rod lever bolts
notsure0
I'm stuck trying to remove the lower unit because the part number 0326644 shift rod lever won't let the shift lever loose. It has a bolt that's visible on top, and then a flat head on the bracket off to the side, which I'm told has to be removed. No tool in the world could get in there. So I took off the carbs& now that I can hardly get to this screw, it's sunken down low into the steel. Both the flat head screw and the bolt. I can't get any wrench in there good enough to get it out. I can't get a straight shot to drive it out with any drill or air wrench. I'm ready to take this whole thing apart. It's sitting on the floor. What would you remove next? If you could not get that bracket off?
notsure0
The model plate is gone. I can give you pictures and any part numbers. They won't let me upload any pictures here for some reason.
The engine is a V6 20" shaft and the cowling says Evinrude 150hp VRO V6. It's navy blue. I think it's 1989-1991 model.
Honorary Supreme Mariner
The pin you need to remove is horizontal.-----Either a screw driver or a 3/8" socket is used.----Tools come in from starboard side of the motor.----Do not remove any other screws.---You can shift motor to get a better view of that screw / pin.
FarmallM
I just did my '91 Johnson 120 & removed port half of lower engine housing by removing 4 bolts on starboard side.
A 91 looper may not disconnect the same way as the motor in post # 1 in this case !!
