evinrude 150 outboard E150ELEDB
clc13e
I have a 95 Evinrude 150, that will not stay running. When you go to start it up it will run for 5 to 10 seconds and then die. I tried to squeeze the bulb to keep it running, but it did not make a difference. I empted the fuel tank and filled it with fresh fuel, good battery, kill switch in place, but will just will not stay running. Anyone seen this or can offer any help. Thanks!!!
ob
Re: evinrude 150 outboard E150ELEDB
See if you can keep it running longer by either intermittedly pushing in on the key primer or leaving it depressed once the engine starts.If so ,your carburetors are likely fouled and will require disassembly and cleaning.
